  New Posts New Posts RSS Feed - Can't Run Library Expert Lite - Licence Server?
MarcoHess View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarcoHess Quote  Post ReplyReply Direct Link To This Post Topic: Can't Run Library Expert Lite - Licence Server?
    Posted: 03 May 2016 at 12:02am
On one of my PC's I tried to install Library Expert Lite but when I try to run it it gives me a dialogue box with the title:
FPX_2016
and the message:
Unable to continue - licence server not found.
I have uninstalled, reinstalled and upgraded to the latest version to no avail. Same error message every time.
Why does Expert Lite look for a licence server? How can I run Expert Lite without this problem?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2016 at 6:26am
You likely use a Proxy Server. Please try the following (Win10), but you should be able to follow along the way for Win7 and Win8:
  1. Open "Settings" or "Control "Panel"
  2. Select "Network and Sharing Center"
  3. Select "Internet Options", "Connections" tab, and "LAN Settings" button
  4. Select the "Advanced" button
  5. Add "www.PCBLibraries.com" to the exception list and click OK
If you prefer, you can also take advantage of the Library Expert Pro promotions we have and get in at a good price. The Professional comes with access to over 1 million dynamic parts (that get stamped with YOUR preferences), and all posted prices are for perpetual licenses (they do not expire), and you have updates for all of version 2016.
Please contact us offline if you want a price quote.
PLTcbv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PLTcbv Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2017 at 5:17am
 I had the same issue this morning when my internet connection was down.
It looks like that you only can use the Library Expert Lite (2017.09) software with an internet connection and not disconnected.
The System Requirements.txt file is saying "- Internet connection is required for connecting to the Parts on Demand database" so disconnected should the Lite version work because I'm not using the POD database
What is happening?
Regards, Wim.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2017 at 9:11am
The Lite version needs to connect to the server to stream ads. No connection will lock up the Lite. The Pro version doesn't have ads and does not require an internet connection. Neither does the POD Builder version. www.PCBLibraries.com/Products/Compare
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2017 at 9:16am
Thanks for pointing this out, the Requirements file was updated to clarify this.
pnguyen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pnguyen Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2017 at 1:25pm
can we make Lite go throught proxy ? with proxy password ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2017 at 1:37pm
Proxy servers are not currently supported.
aricbeaver View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aricbeaver Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2018 at 11:53am
Are proxy servers still not supported? Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2018 at 12:04pm
Correct.
This page was generated in 1.469 seconds.
