  New Posts New Posts RSS Feed - Library Expert 2016.04 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2016.04 Released!!
    Posted: 30 Apr 2016 at 9:15am
NEW / ENHANCED:
  • Calculator:
    • 3-pin DFN – Added the IC component family
  • Preferences:
    • Updated the “Drafting > Legend > Auto-generate Pin 1 Indicator Line” to include 2-pin parts
    • Updated all the wireframe models for editing color assignments
    • Updated solder mask size resolution to 3 decimal places
    • Updated the Finish Tab to automatically add spaces to the Case Code if it is used to generate the Footprint Name
    • Removed the period . as an illegal character for a footprint name
  • 3D STEP:
  • CR-8000:
    • Added a new option for CR-8000. The only difference between this and CR-5000 is that radius values will be built properly per spec. It’s a known bug in Zuken CR-5000 that the radius of a curve must be negative to display properly. This was fixed in Zuken CR-8000 and the output for this translator has now been adjusted to match, while allowing the CR-5000 that is correct to remain the same.
  • CADSTAR:
    • Added support for CADSTAR 17
  • Allegro/OrCAD PCB:
    • Added keep-outs
    • If using a Courtyard No Probe Area, the No Probe Area will be circular for Radial Electrolytic, Radial Inductor, and Radial LED Land Patterns
FIXED:
  • 3D STEP:
    • Fixed an issue that was causing XTAL’s to not expand their height properly
    • When the material condition is set to Maximum or Minimum in the 3D window, if a Maximum or Minimum value does not exist for a parameter, the Nominal value will now be used
  • CADSTAR:
    • Terminal Outlines will be mapped to the Component Outline (Top 3D Model Outline by default) layer
  • Expedition:
    • Fixed an issue with thermal tab paste mask, when the thermal tab is offset from the origin
