  New Posts New Posts RSS Feed - Collapsing vs: Non-Collapsing BGA Balls
lsday View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lsday Quote  Post ReplyReply Direct Link To This Post Topic: Collapsing vs: Non-Collapsing BGA Balls
    Posted: 06 Apr 2016 at 7:37am
How does one know if the BGA (CSP) has collapsing or non-collapsing solder balls?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2016 at 7:44am
Non-collapsing BGA's normally are 0.50 mm pitch or less.
There are various Chip Scale Packages where the mfr. calls the package a BGA but instead of a Ball there is only a bump. This is also a non-collapsing BGA.
All other BGA's are Collapsing Balls.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lsday Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2016 at 9:09am
Thank you for the clarification Tom.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2016 at 7:21am
This is what a Collapsing BGA Ball looks like -
Here is a non-collapsing BGA ball with a solder mask defined pad. IPC has guidance to avoid this, but it's impossible for pin pitches below 0.65 mm if there are traces on the same layer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eng. Jesus Mora Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2018 at 10:12am
Hello Tom,
For fine pitch BGA's using the non-collapsing ball in PCB Library expert program we always have default Solder mask expansion of 0 mils. Do you recommend for all fine-pitch non-collapsing ball to use 0 mils expansion? or what is your recommendation for SM expansion in these cases?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2018 at 11:34am
Non-collapsing BGA balls start at 0.50 mm pitch and less.
The pad size is larger because you need to do via-in-pad and you need an annular ring.
The solder mask swell = 0 or even -0.05 mm to solder mask define.
Even if you can use 2 mil trace/space to escape the second rows, the solder mask must always cover the trace to avoid solder bridging between trace and pad.
A 0.50 mm pitch non-collapsing ball size average is 0.25 mm diameter with a pad of 0.33 mm diameter. This leaves a 0.17 mm gap between pads. 0.05 mm trace/space = 0.15 mm but you must consider a 0.025 mm tolerance on the solder mask registration.
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 49 minutes ago at 8:29pm
is this information collapsing or non collapsing be mentione in supplier datasheets, or just depend on pitch value only, also pich value foun in IPC- standard?
