  New Posts New Posts RSS Feed - Library Expert 2016.02 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2016.02 Released!!
    Posted: 14 Mar 2016 at 3:37pm
NEW:
  • Calculator:
    • Added Radial Disk Resistors and Varistors
    • A new attribute was added for the part number on the assembly layer
  • Altium:
    • Add Reference Designator to user definable layer in CAD output menu
  • Xpedition:
    • Added Top, Bottom and All Layer Keep-outs
FIXED / ENHANCED:
  • General / Calculator:
    • Updated Sample.fpx
    • Fixed an issue with filled Polarity Markers were translated as Copper and not 2D Lines
    • The Part Type (Part Number) text object will now be placed on the assembly layer for all CAD tools
    • Fixed a legend trimming bug
  • Preferences:
    • Updated the default color assignments for Keep-outs
  • Allegro/OrCAD PCB:
    • Fixed an issue dealing with naming, when you have multiple pad stacks that are nearly the same
    • Fixed an issue when dealing with values to 4 decimal places getting rounded to 3 decimal places
  • EAGLE:
    • At a Solder Mask or Paste Mask expansion value of 0, the Eagle rules will now take over and the Solder Mask and Paste Mask will be generated internally by Eagle. The exception for this is a Thermal Tab. All thermal tabs will have their Solder Mask and Paste Mask generated manually.
  • KiCad:
    • Fixed a missing bracket “(“ before the "descr" keyword in the *.kicad_mod file
    • Added the ability to have a Part Type value as VAL**.
  • PADS p/d Files:
    • Updated PADS p/d files – www.pcblibraries.com/downloads
  • Library Expert Lite:
    • Fixed the Oscillator a pin limit from 0 to 6
This page was generated in 2.176 seconds.
