  New Posts New Posts RSS Feed - Use Manufacturer's Fecommended Footprint?
EW_FrankO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EW_FrankO Quote  Post ReplyReply Direct Link To This Post Topic: Use Manufacturer's Fecommended Footprint?
    Posted: 29 Feb 2016 at 3:59am
Maybe it's a feature and I do not understand this feature.
... under:
Footprint
Dimensions Use manufacturer's recommended dimensions.
There is a radiobox.
If I select (Use manufacturer's recommended dimensions), I can edit.
If I unselect, it is greyed out.
... and no Button to restore the manufacturer's recommended dimensions.
Which
Manufacturer's Recommended Dimensions does it effect?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2016 at 8:10am
After you enter the physical component dimensions you can select the Footprint tab and enter the mfr. recommended pad sizes and spacing.
The you can look at the viewer and see where the pad is in relation to the Component Terminal Leads.
If the Terminal Leads fall off the pad then the mfr. recommended pattern is faulty.
If you get good results then add the data to your FPX file.
Then you can remove the Footprint Dimensions and see the IPC-7351 pattern.
If you want to recall the Mfr. Recommended Footprint reopen the part in the FPX file that you saved.
This page was generated in 3.172 seconds.
