Forum Home Forum Home > Libraries > Footprints / Land Patterns > Xpedition
  New Posts New Posts RSS Feed - Encrypted ascii
Encrypted ascii
magnus.lictor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote magnus.lictor Quote  Post ReplyReply Direct Link To This Post Topic: Encrypted ascii
    Posted: 05 Feb 2016 at 7:00am
I am evaluating Library Ezpert Lite, version 2015-21.
When I add all the data for a cell, I want to create the "Encrypted Ascii" file.  I click the "Build Part"
button and the "create footprint" window opens up.
I select the Expedition Translator, set the ouput format to "Encrypted Ascii, select an output directory  and click on the "create" button.
Now a NOT encrypted ascii file is generated, and after this a window opens up:
"No executable file found".
As we are using VX, I cannot add non-encrypted file to the library.
regards, Magnus
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2016 at 7:26am
Can you please confirm that you have the "EncryptData.exe" file in the program directory? The default program directory for the Lite is
C:\Program Files (x86)\PCB Libraries\Library Expert 2015 Lite
If not, please download the latest 2015.21 build (the initial one didn't have this file) and try again.
Regards,
Nick
Post Options Post Options   Thanks (0) Thanks(0)   Quote magnus.lictor Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 6:22am
The "EncryptData.exe" isn't there.  I have downloaded the 2015.21 again, now it is there and everything is working.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 7:28am
Thanks for confirming!
