  New Posts New Posts RSS Feed - Allegro Output for Non-plated Holes
lalexman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Topic: Allegro Output for Non-plated Holes
    Posted: 24 Dec 2015 at 6:22am
When you generate a non-plated mounting hole an error is generated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2015 at 9:15am
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2015 at 9:20am
I am only trying to create a round non plated mounting hole. I do not see a donut in the padstack. Am I missing something ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2015 at 9:57am
Allegro 16.6 does not support "Donut Pads".
Allegro 17.0 will support "Donut Pads".
PADS Layout has supported "Donut Pads" for the past 15 years.
Altium supports "Donut Pads" in the latest release.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2016 at 6:07pm
Did you figure this out?
V2015.21 pre-release is available here - www.pcblibraries.com/downloads
Post Options Post Options   Thanks (1) Thanks(1)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2016 at 6:10pm
Yes I was generating the pad size larger that the hole size and it created the donut shape that did not work.
This page was generated in 0.202 seconds.
