  New Posts New Posts RSS Feed - Changes in 2015.20 ?
Matthew Lamkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matthew Lamkin Quote  Post ReplyReply Direct Link To This Post Topic: Changes in 2015.20 ?
    Posted: 17 Dec 2015 at 9:50am
Hello, can I ask what the method was and what it is now?
Kind of a why question?
Just being nosey - but it helps me if I know more about any CADSTAR things.CADSTAR:
    • The method of footprint naming was reverted back to pre V2015.19 terminology
Thank you,
Matthew
Post Options Post Options   Thanks (1) Thanks(1)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2015 at 11:32am
IIRC, In 2015.19 a change was made to the name/alternate name structure. Normally it had Name as the regular name and then alternate name as the environment level. This was changed so that it had regular name, and then name minus environment level and was deemed to be bad form and incorrect for what users need for CADSTAR and was reverted to the original style of environment level as the alternate name.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matthew Lamkin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2015 at 3:31am
Cheers Chris.
This page was generated in 0.264 seconds.
