  New Posts New Posts RSS Feed - how to use PTH reference calculator
fishoutofwater View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote fishoutofwater Quote  Post ReplyReply Direct Link To This Post Topic: how to use PTH reference calculator
    Posted: 04 Nov 2015 at 1:35pm
Hello again,
I have a few more basic question, regarding the PTH reference calculator:
1. Hole over Lead - this refers to how much larger the hole diameter should be, WRT lead diameter?
2. Minimum Annular Ring - this refers to the minimum pad-hole width, irrespective of the Pad-to-Hole ratio?
3. Thermal ID over Hole - this refers to the min distance between a hole and a plane it passes through, but does not want to connect to?
4. What is the difference between the pad on layer3 (thermal pad) and the antipad on layer4, other than that the antipad is bigger?
5. Thermal OD to Hole ratio - why do we need to specify this? Isn't both the Thermal OD and Hole diameter already specified previously?
6. Spoke width - why is it specified as 75?
Thank you very much.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2015 at 9:40am
1. Yes, WRT lead diameter or diagonal if not round.
2. Yes, Minimum Annular Ring will never be less than this value.
3. Thermal ID over Hole defines the inner clearance, Thermal OD is the outer clearance.  The clearance is bridged by the spokes.
4. Thermal OD and Anti-pad are equal.
5. Thermal OD to Hole ratio allows the OD to increase in proportion to the hole.
6. Spoke width is calculated as a (percent of the thermal OD) / 4. 75% is the default.
Post Options Post Options   Thanks (1) Thanks(1)   Quote fishoutofwater Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2015 at 9:54am
Thank you!
This page was generated in 2.000 seconds.
