  New Posts New Posts RSS Feed - Auto Update?
Auto Update?
Matthew Lamkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matthew Lamkin Quote  Post ReplyReply Direct Link To This Post Topic: Auto Update?
    Posted: 04 Nov 2015 at 2:35am
Gent's, you update this program (LE) daily, weekly, monthly - or when the wind changes. Tongue
Isn't it about time you added the option to check for updates and to auto update into the program like many other applications do?
So a user starts the program and it does a quick check of the server to see if there is an update - when there is prompt to install it or download for later install?
Rather than a user having to go to the help & manually check for an update, which does very little, it does not even prompt you to visit the website download page.
Cheers,
Matthew
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2015 at 8:02am
The releases come after every reported bug is fixed and tested including the New Features fully tested.
When a new release comes out, the user is reminded if they do not install it after 1 week.
Note: V2015.18 was available for the entire month of October but we never sent out a release notification. Several people downloaded it and reported minor issues and we kept on fixing the problems and re-uploading updates. It is very important that if you downloaded and installed V2015.18 in October to download the official release after the notification was sent out.
We are bringing back Auto-update in the next release - V2015.19
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matthew Lamkin Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2015 at 8:25am
I don't recall ever seeing an update notification?
Maybe I don't run the program enough :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2015 at 9:13am
The auto-update is at the mercy of any firewall or antivirus (hardware and software) you have on your end.
jmgaskill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmgaskill Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2015 at 10:42am
...just downloaded V2015.19; where do we find the update option?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2015 at 10:59am
The auto-update runs once every week, if allowed by your computer and network (antivirus and firewall can prevent this from happening). By default it's turned on to check if an update is posted, if 7 days lapsed since the last time the Library Expert ran and no update was applied.
Nick
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmgaskill Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2015 at 11:16am
Thanks Nick -- which network port(s) do we need to have open to support auto-update?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2015 at 11:58am
The Library Expert uses an installer called QSetup, which creates an AutoUpdate.exe file that looks something like:
FPX2015PRO_AutoUpdate.exe
Which gets placed on installation of the Library Expert (by default) in this directory:
C:\Program Files (x86)\PCB Libraries\
Once per week, when the Library Expert is started, it uses this program to check for updates via HTTP protocol on port 80. If this program is quarantined or is frozen up by an anti-virus program it can do nothing.
