  New Posts New Posts RSS Feed - "Pad size is zero" error when using Allegro batch
tjrehberger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tjrehberger Quote  Post ReplyReply Direct Link To This Post Topic: "Pad size is zero" error when using Allegro batch
    Posted: 20 Oct 2015 at 8:58am
Whenever I run the Allegro batch scripts for surface mount parts I get an error in Pad Designer:
PADSTACK ERRORS and WARNINGS:
SOLDERMASK_TOP : Pad size is zero.
PASTEMASK_TOP : Pad size is zero.
Those layers have the 'Shape' property populated with some generated name, but 'Width' and 'Height' are both 0. I'm using 16.6, and PCBLE2015. Anyone have any ideas on how to fix this? Please let me know if it would be helpful to include my source files or logs or anything.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 9:03am
Please send us the FPX file that you are using and we'll try to reproduce this issue.
Also include your contact info so we can do a webcast to see your screen if we can't duplicate the issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tjrehberger Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 9:10am
Thanks Tom, I've emailed you the file!
