  New Posts New Posts RSS Feed - LE2015_16_PRO and PADS VX1.1 Problem
layouter88 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote layouter88 Quote  Post ReplyReply Direct Link To This Post Topic: LE2015_16_PRO and PADS VX1.1 Problem
    Posted: 04 Sep 2015 at 7:54am
Hello
I just installed  version 16 of the LE  (had Version 14 in use before without Problems)
I try to build a part and always get the message
Unable to connect to the running PADS application
A) Confirm that PADS Power PCB is running and at Board (PCB) Level
B) Try running PADS Power PCB as "Run As Administrator' via a shortcut on the Desktop.
whatever I am doing, it does not work.
Instead there are two Files generated  in my libraries target folder
decalname.d    and
part type name.p
is there a change in the bahaviour beetween v14 and v16 and I have to Change a Setting manually?
Best regards
Erwin
Post Options Post Options   Thanks (0) Thanks(0)   Quote layouter88 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2015 at 8:03am
Solved
after running Mentor release switch  everything works fine again.
Best regards
Erwin
