  New Posts New Posts RSS Feed - Standard Chip Component Dimensions
drj-bbe View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote drj-bbe Quote  Post ReplyReply Direct Link To This Post Topic: Standard Chip Component Dimensions
    Posted: 08 Jul 2015 at 3:28am
I am trying to find a standard land pattern for chip resistor or capacitor, ex. 0402, 0603, etc.
But one chip component may have different tolerance between each manufacturer, and land pattern calculated by Library Expert Pro will be different if according to component datasheet. If like this then I cannot get uniform land pattern design for one type component on board.
Is there a Industrial Standard for components package dimension? or some suggestions to make standard land pattern for one type component?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2015 at 7:50am
There are no EIA, JEDEC or IPC standards on chip size dimensions.
Here is the closest you will get to the Standard Case Sizes but good luck trying to find a manufacturer that uses these dimensions. Notice that the Height and Tolerances are missing because that is unique for every manufacturer. And the Height plays into the Toe solder joint calculation and the tolerances affect every aspect of the Land Pattern (footprint).
Download the document "Surface Mount Components" here - www.pcblibraries.com/downloads
It illustrates all the various types of SMD packages and the variety of Chip components.
Post Options Post Options   Thanks (1) Thanks(1)   Quote drj-bbe Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2015 at 7:38pm
Thanks for your reply.
Yes, Height and Tolerances can afftect land pattern size, and it is unique for every manufacturer.
But I cannot make unique land pattern for every manufacturer for an ex. 0603 component. I peffer to use only one land pattern for all brand 0603 components, not make many land patterns for a standard chip part in our library.
Could you please give your advice on this?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2015 at 9:03am
Let's figure out what you really want. Do you want to use the same footprint for every 0603 Chip component in the electronics industry regardless of their tolerance and package height?
Post Options Post Options   Thanks (1) Thanks(1)   Quote drj-bbe Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2015 at 6:14pm
Sorry, I just want to use the same footprint for every 0603 Capacitor and Resistor regardless of their tolerance and package height.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2015 at 8:09pm
Here is the 2016 J-STD-001 SMD Proportional pad stack table for pad size calculations for Chip components. The Courtyard Excess has a 0.25 mm limiter on it, but all the percentages and values are user definable.
Good luck with finding a single footprint to successfully accommodate every 0603 package. The Height is the main driver of this component lead form.
Issue: if you use a 0603 land pattern considering the highest package, you may be dumping too much solder on an 0603 that is 50% of that height, introducing potential tomb-stoning.
This new Proportional SMD technology will be available in the V2016 Library Expert.
Post Options Post Options   Thanks (1) Thanks(1)   Quote drj-bbe Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2015 at 8:40pm
Many thanks for your feedback on this.
In order to understand fully the table you provided, I tried to find the table in IPC-J-STD-001F, but not see it. For 2016 J-STD-001, is it new version?
I didn't find it in IPC website, only find F version.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2015 at 8:56am
This is new (unreleased) technology that we are testing this summer. It might be added to IPC-7351C but IPC wants it fully tested first.
I am a CIT trainer and teach hand soldering techniques to students.
The J-STD-001 has guidelines for minimum and maximum solder joint goal ranges. Every Terminal Lead form has it's specific percentages for pad size calculations. Example: Gull Wing lead is based on percentage of the pin pitch.
I'm just giving you a glimpse of the near future that you will not find in any publication today, will be in every standard next year.
Post Options Post Options   Thanks (1) Thanks(1)   Quote drj-bbe Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2015 at 7:03pm
Thanks for your information.
There is a principles in IPC-7351B for 0603 component below. It seems different with the table you provided.  The current principles will be replaced by new technology, right?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2015 at 7:30pm
That is the correct table for the 2010 version of IPC-7351B.
For your 0603, it falls in the large component type and the same solder joint rules apply in both the IPC-7351B and IPC-7351C.
Here is the updated table for IPC-7351C and this is in V2015.15 of Library Expert Pro, Lite and Viewer for the smaller chip sizes.
As you can see, 0402, 0201 and 01005 have different Toe goals to prevent tomb-stoning.
