  New Posts New Posts RSS Feed - Changing Pin Numbering on an SOL Footprint
SteveD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveD Quote  Post ReplyReply Direct Link To This Post Topic: Changing Pin Numbering on an SOL Footprint
    Posted: 16 Jun 2015 at 9:16pm
Using the surface mount tool, how do I change the default SO pin numbering from top down left and bottom up right to alternating top down left-right, left-right?
1  8    -> 1  2
2  7 3  4
3  6 5  6
4  5  7  8
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2015 at 6:22am
It looks mirrored to me.
Did you try to select the "Mirror" icon in the toolbar?
Just one click and you're ready to roll.
Please attach a web-link to the component package datasheet.
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveD Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2015 at 9:12am
That does not produce the desired pin sequence shown above.
It is not just mirrored.  It's 'rolfed.'
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2015 at 9:32am
This is a datasheet for 4-pin Gull Wing Tactile Switches. Not 8-pin SOL package.
There is no IPC Calculator for Tactile Switches.
We created FP Designer to make these footprints and you have 100% control of the pin assignments.
