Forum Home Forum Home > Libraries > Footprints / Land Patterns > Xpedition
  New Posts New Posts RSS Feed - ALERT: Expedition VX.1 - Solution w/Library Expert
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Topic: ALERT: Expedition VX.1 - Solution w/Library Expert
    Posted: 08 Jun 2015 at 12:21pm
We finally figured out a solution for the Library Expert to auto-import library data directly to Expedition VX.1. We have confirmed it does work on a beta customer machine, so hopefully it will work for everybody else. This is only for customers using Expedition VX.
In order for the Direct Import to work with VX.1, you're going to need to make the following change.
Right click on the Library Expert desktop icon and select the "Properties" option and change the "Target" to be:
C:\MentorGraphics\EEVX.1.1\SDD_HOME\common\win32\bin\mglaunch.exe "C:\Program Files (x86)\PCB Libraries\Library Expert 2015\FPX_2015_Pro.exe"
Make sure mglaunch is in that location or change the directory to your personal Expedition path so it points to the location of mglaunch. Also make sure the path for Library Expert matches where you installed the program. Make sure Run As Administrator is turned on via the Advanced... button, then run the icon and run everything as normal and see if Direct Import into VX Expedition does its thing.
What it should do is launch a shell program which exposes the LibraryManager of VX to the program so that it can then interact with it, allowing it to run.
dcayen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dcayen Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2015 at 4:50am
This solution is not working for me. I do see the shell program and it looks like it should work but when I build a part when the progress bar reaches about 60% I get the following error:
PCBL Libraries Expert Pro has stopped working
A problem caused the program to stop working correctly. Please close the program.
The only thing that I can do at that point is click the button to close the program.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2015 at 7:17am
It's likely a problem with the FPX file. We will contact you offline.
This page was generated in 0.221 seconds.
