  New Posts New Posts RSS Feed - Add SOT89-3 & 5 Pin Versions to IPC Calculator
stampedeboss View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote stampedeboss Quote  Post ReplyReply Direct Link To This Post Topic: Add SOT89-3 & 5 Pin Versions to IPC Calculator
    Posted: 31 May 2015 at 1:54am
With more uses of the SOT89-5 package in voltage related chips, can it be added to where the Expert Lite version can create the footprint?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2015 at 6:17am
You can order any SOT89 here - www.pcblibraries.com/pod
We will also add SOT89 to V2016 as a standard component family.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stampedeboss Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2015 at 8:09am
Problem with POD is finding the SOT89-5 footprint.  The component I need it for is not listed:
POW PT4115B
I don't know which manufacturer to select.
Thank you for the V2016 update.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2015 at 8:43am
Thanks for your comments, we're working on enhancing the PCB POD experience.
PLTcbv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PLTcbv Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2016 at 7:13am
Just checked the 2016.02 LITE version but no SOT89 component family.
In which 2016 wil it be implemented?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2016 at 7:23am
SOT89 has a irregular shape pad and the unique pad feature is going into V2017.
This page was generated in 1.289 seconds.
