  New Posts New Posts RSS Feed - Library Expert 2015.13 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2015.13 Released!!
    Posted: 27 May 2015 at 3:35pm
NEW:
  • Setup Preferences:
    • Totally redesigned GUI to make this feature more User Friendly
    • User Preferences have been removed
    • Default Preferences are now just “Preferences”
  • FP Designer – Drawing Button:
    • Added new polarity marking for Triangles, Diode Symbols and Lines
    • Added Assembly Drawing Top layer to polarity markings
    • Added a new feature for creating a .bak backup file when you save your FPX file
FIXED / ENHANCED:
  • Calculator:
    • Fixed an issue in the DIODFN component family pin re-mapping C & A to A & C
    • Fixed an issue with keep-outs not following the selections
  • Default Preferences:
    • Minimum Annular Ring now map correctly to the Calculator parts
    • Fixed an issue where under certain conditions, deleting and adding parts caused new parts not to be saved
  • 3D STEP:
    • Updated the LCC component family for the rectangular version
  • CR-5000:
    • PTH holes should now be translating properly
    • Fixed a problem with 180 degree arcs in pads getting flattened by CR-5000. They were converted into two 90 degree arcs, which should achieve the desired result.
    • Pads on the Inner layer now have their No Connect back
  • PADS Layout:
    • Fixed an issue that was causing the PADS to FPX conversion to not handle pad offsets properly
  • Master FPX:
