  New Posts New Posts RSS Feed - No Donuts for Allegro
DaveCowl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCowl Quote  Post ReplyReply Direct Link To This Post Topic: No Donuts for Allegro
    Posted: 18 May 2015 at 6:33pm
Is there any solution for this issue? I know that I have seen Donuts in Allegro (though I am not sure how they were made).
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2015 at 12:47am
If there is a way, I have yet to find it. I've even tried building it from a cut polygon as a complex pad shape and the way Allegro builds their polygons precludes it. If you find a way, let me know.. i'd be happy to add the functionality if it exists.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCowl Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2015 at 10:39am
I have a board with such a pad so I will see if I can extract it and send it to you, or at least work out how our layout house did it.
Cheers! Dave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCowl Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2015 at 1:33pm
It looks like it is not handled at the pad level, rather in the Symbol Drawing, where there is a void created in the middle of the larger circular pad.
I have emailed the files that were used to create the final symbol for clarification.
Cheers! Dave.
This page was generated in 0.891 seconds.
