  New Posts New Posts RSS Feed - Import Preferences from v2014 into v2015
GrungyRemnant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GrungyRemnant Quote  Post ReplyReply Direct Link To This Post Topic: Import Preferences from v2014 into v2015
    Posted: 07 May 2015 at 9:29am
Hi. I was wondering how I can use my version 2014 user and default preferences with the new 2015 version.  Trying to open them says it is incompatible with the current version.
I can't seem to find any info on doing this and I don't want to redo them from scratch.    Can anyone help?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2015 at 9:42am
The header in the V2015 .DAT file is 2014 so everything should work OK.
Send us your Default .DAT file.
I would not use "USER Preferences" as they will eventually be removed from the program and only Default Preferences will be available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2015 at 9:43am
2014 and 2015 formats are identical.
Send your file to Nick, Tom or Jeff and we'll take a look at it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GrungyRemnant Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2015 at 9:59am
Thanks for the reply.
I looked again.  Just to clarify, it turns out I can import the preferences for the User Preferences - Default Preferences Source but when I select the User Preferences - User Preferences Source it gives me the warning.
Are you saying I should just ignore the User Preferences Source setting and leave it at default(install path\PCB Libraries\Library Expert 2015\UserPreferences.dat)?  The settings in UserPreferences.dat wil not affect anything anymore?  If not then I'm good, but if it does then I might have some issues.
I find the preference setups to be confusing, I'm glad to hear one will be going away. Smile
Chris
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2015 at 10:12am
Do not try to load User Preferences into Default Preferences or you will get a Warning Message that you cannot do that.
I'm saying that in a future release that User Preferences will be removed because no one uses them. Having 2 sets of preferences causes 50% of our technical support issues. So we're just supporting "Default Preferences" in the future.
In the Setup Preferences > Design tab set your Density Level to Nominal and use the 3-Tier library system. User Preferences are only 1-Tier.
