  New Posts New Posts RSS Feed - Recommended DO-214AC
wheels1234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheels1234 Quote  Post ReplyReply Direct Link To This Post Topic: Recommended DO-214AC
    Posted: 07 May 2015 at 5:03am
Question on a Fairchild recommended Land Pattern.
Does anyone understand why this Fairchild is so different from what is typically recommend?
What would you follow?
https://www.fairchildsemi.com/datasheets/ES/ES1J.pdf
John W
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2015 at 9:03am
Fairchild need to update their Package data to whole metric numbers. They just took the old Inch based part and converted the numbers.
The Heel Joint recommendation is only 0.30 mm and IPC-7351 recommends 0.50 mm. However, the datasheet does say "Minimum Recommendation" so that leaves it up to the user to figure out what the Nominal or Maximum should be.
This page was generated in 0.750 seconds.
