  New Posts New Posts RSS Feed - Modify Library Expert Outputs or Export Terminals
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eng. Jesus Mora Quote  Post ReplyReply Direct Link To This Post Topic: Modify Library Expert Outputs or Export Terminals
    Posted: 29 Apr 2015 at 1:07pm
Is there a way we can modify what comes out in the outputs for pads or Altium Designer, because right now all the mechanical layers that get exported are locked, is there a way to modify what goes on each layer?
Also is there a way we could export the terminal outline layer to pads or Altium? it would be of great help if we could get a layer with that info exported.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2015 at 4:35pm
The parts are built as is.
Once they're in the tool (PADS or Altium), you should be able to do anything you want to with them.
I'll take a look at exporting the terminal outline.
