  New Posts New Posts RSS Feed - TO-277A
TO-277A
MSM_KOPF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MSM_KOPF Quote  Post ReplyReply Direct Link To This Post Topic: TO-277A
    Posted: 22 Apr 2015 at 7:24am
Vishay for example uses for the SS5P6 the TO-277A package, they call this package SMPC
This package is not an Transistor Outline (TO, DPAK) as there are no gull wing leads, nor is it an SOTFL as the lead width is not the same for all leads.
What would be the recommended way to generate such a footprint with Library Expert Pro ?
(we actually still stay with 2015-08)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2015 at 10:56am
The JEDEC TO-277A Package is not in the IPC-7351 standard yet.
You can create this footprint in less than 5 minutes in FP Designer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2015 at 10:58am
I would highly recommend that you upgrade to the V2015.11 release next week.
You can get the V2015.11 pre-release right now - www.pcblibraries.com/downloads
Post Options Post Options   Thanks (0) Thanks(0)   Quote MSM_KOPF Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2015 at 11:59pm
What about reusing the modified and saved saved preferences (User and Default) from 2015-08 to 2015-11?
Is it just an installation of the new version and pointing to the existing old preferences or do we need
to obey something ? checking all component settings for example.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2015 at 4:57am
The program automatically keeps and updates your Preference files with any new features. When you install the Library Expert it uninstalls the old version and installs the new version but it never deletes your Preference or FPX files.
Important Note: In the next release, we are removing User and Default Preferences as they are redundant Preferences. When you open the Preferences menu everything will be just "Preferences". You will be able to load your existing Default Preference files into the new menu. You will be able to create and Save new Preferences.
