  New Posts New Posts RSS Feed - Setup > Preferences Menu Graphics?
AGONZ67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AGONZ67 Quote  Post ReplyReply Direct Link To This Post Topic: Setup > Preferences Menu Graphics?
    Posted: 22 May 2012 at 9:35am
Under the Setup menu when you select an item to modify would it be possible to have a graphic display of the item you are modifying?
For example under setup-components-surface mount-PLCC the PLCC package would display under the 'component family options' on the right.
Perhaps the display could update showing orientation & origin etc. as it is selected?
Chris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2012 at 11:30am
Sounds like a nice added bonus to the set-up window it's always nice to see what it is you are actually changing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2013 at 11:45am
We added component lead pictures in V2013 so you can visually see where the Toe and Heel are in both the Calculator and in User Preferences.
The Molded Body and J-Lead are the only 2 component families that have the Heel on the outside.
This page was generated in 0.423 seconds.
