  New Posts New Posts RSS Feed - Renumber pins and move pin 1 location
lalexman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Topic: Renumber pins and move pin 1 location
    Posted: 27 Mar 2015 at 5:35am
I have the following bga that needs pin 1 on the top left and the pins renamed A1 a2 a3 on the top row. How can I accomplish this ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2015 at 6:46am
The problem is I have a 6 pin bga that I want to renumber the alphanumeric pins. How do you do this. If I select he properties I cannot change the pin name. Also I need to move the pin 1 silkscreen from the bottom left to the  top left after I renumber  the pins. How do you do this also ?
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2015 at 6:46am
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2015 at 6:50am
Thanks Tom. That was too easy.
