"ContainerNotFound" ERROR |
Page 12> |
Nick B
Topic: "ContainerNotFound" ERRORPosted: 19 Mar 2015 at 6:06pm |
If you get the "Container not found" error (as shown below), it generally means that
Here's what the message typically looks like: "The License server has encountered a problem: ContainerNotFound Program will continue to run with limited licensed options." ![]() |
rtennill
Thanks(1)
Posted: 25 Sep 2017 at 8:32am |
This can also be a network issue. I consistently get this error when launching the software in a freshly booted virtual machine. I give it a minute then try again and it usually finds the license server.
Nick B
Posted: 25 Sep 2017 at 11:11am |
Thanks for your input, that is correct - this error also can get triggered when a Network License is used and a network connection is lost (or not properly established between the client and server).
magnus.lictor
Joined: 27 Aug 2012 Location: Amsterdam, NL Status: Offline Points: 64 |
Posted: 02 Nov 2018 at 1:39am |
Hi, I do have the same problem.
I think i know what is wrong but i have no clue how to fix it. The license sever is running on a machine with the IP adress 145.xxx.xxx.xxx. All the machines that are in the same sub-net can run the software without any problems. However, there is one machine that has an IP adress in the 195.xxx.xxx.xxx subnet. This machine gets the " ContainerNotFound" error. |
Nick B
Posted: 02 Nov 2018 at 7:29am |
Per the original post (see link above), please check that the machine with this problem1. Has the current drivers (runtime 7.08 at this time)
2. Does not have the Sentinel service stopped |
magnus.lictor
Posted: 05 Nov 2018 at 5:37am |
The sentinel driver is running. It finds an other license manager on that part of the network,
The version installed is Version 7.80, April 2018This version is running on both machines
Nick B
Posted: 05 Nov 2018 at 8:01am |
I will contact you via email.
wilburh
Posted: 20 Feb 2019 at 9:04am |
I am getting the same Container Not Found message.
The machine is question is a Windows 10 VM running under a Linux host. The network connection is NAT. The same machine has no problems obtaining the licenses from the Mentor Graphics License server.
Nick B
Posted: 20 Feb 2019 at 9:23am |
I will contact you offline to troubleshoot.
IntelDCG
Posted: 30 Apr 2019 at 12:22pm |
I
get this error however reinstalling LE-E-2019-2 and the Sentinel ACC server software was no help.I don't think my license server has licenses anymore.
Page 12> |
