  New Posts New Posts RSS Feed - Series Diode SOT23 Pin Naming
acmenet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acmenet Quote  Post ReplyReply Direct Link To This Post Topic: Series Diode SOT23 Pin Naming
    Posted: 12 Mar 2015 at 6:13am
We use the _EBC   and _GSD to name our SOT23 transistor, and is incorported into the IPC name.
How do we achieve the same with series SOT23 diodes, where we have for example:
Anode - Anode/Cathode - Anode
or Anode - Cathode/Anode - Cathode
we don't want to use pin numbering as e have had infinite problems in the past using numbing methods
Look forward to an answer ( sorry if this one has been asked before)
Cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2015 at 6:18am
I recommend this Footprint Naming Convention because you will never get it wrong -
MfrName_MfrPartNumber
That is the footprint naming convention for all connectors and special unique packages.
Post Options Post Options   Thanks (0) Thanks(0)   Quote acmenet Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2015 at 7:15am
Well was hoping to have less long winded way of doing it, but if that they way to go who am I to argue. Big smile
Cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2015 at 7:23am
It's really the universal Footprint Naming Convention of the future.
Component manufacturer's are creating unique packages that do not fall within the IPC-7351 Naming Convention.
So half your library footprint name are IPC-7351 and half are MfrName_MfrPartNumber
Eventually, the Unique Packages will out number the Standard Packages and the IPC-7351 naming convention will fade away. It's already starting to fall apart even with Standard Packages.
If 2, 3 or 4 standard packages have the same identical dimensions but their tolerances are all different, you will end up with different footprints with the same IPC-7351 footprint name.
This page was generated in 0.953 seconds.
