  New Posts New Posts RSS Feed - Add Vertical Mount Style to Axial Family
Ian S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian S Quote  Post ReplyReply Direct Link To This Post Topic: Add Vertical Mount Style to Axial Family
    Posted: 09 Mar 2015 at 5:48am
If possible, please add a Mount Style to the axial family to allow the user to choose between either Horizontal or Vertical.
For polarized diodes, the square pad to identify the cathode would be acceptable (for me at least) but it would be great is the user can select which of the two pins is the cathode.
As you know, as you guys wrote the code in the first place, Mentor's Land Pattern Creator has the above mentioned option.
I would prefer not to use FP Designer for this as it is a standard component.
This page was generated in 0.204 seconds.
