  New Posts New Posts RSS Feed - How Can I Toggle Pin Number From Alpha To Numeric?
Glen.Chen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glen.Chen Quote  Post ReplyReply Direct Link To This Post Topic: How Can I Toggle Pin Number From Alpha To Numeric?
    Posted: 03 Mar 2015 at 12:49am
I can not update the pin number,How does it work??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2015 at 7:39am
If you select a pad and Right Mouse Button select "Numeric Pins".
You can toggle back and forth between Alpha and Numeric pin names.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glen.Chen Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2015 at 7:13pm
I Can Toggle Pin Number From Alpha To Numeric, Thanks!!
But if I want to change the polarity reversed pin number?
Change the Pin1 to the Anode?
How Can I Do It?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2015 at 8:05pm
I forwarded your feature request to the software programmers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glen.Chen Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2015 at 6:41pm
There are the results please tell me, thank you!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glen.Chen Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2015 at 6:51pm
How do I establish the following two irregular pad?
thank you!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glen.Chen Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2015 at 7:08pm
Sorry,I found a chamfered rectangleTongue
But the kind of pad below how to build it?It is divided into four pad to do it? However, only three number or customer number only took one how does it work?
thank you!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2015 at 9:42pm
You cannot create that footprint in Library Expert.
But we can build it and sell it to you and everyone else for $2.
We would create the pads, pin names, solder mask, paste mask, silkscreen and everything else once and do it right and never do it again and no one on this planet would ever have to spend any time creating this library part again.
We are definitely pro-productive and elimination of duplication.
Use www.pcblibraries.com/POD and enter the mfr. name and part number and if it doesn't exist yet, Request it and it will be created and shared with the global electronics industry. You will get an email when the part is ready for download.
We can't make it any easier than that.
This page was generated in 0.434 seconds.
