  New Posts New Posts RSS Feed - Naming Convention On The Molded Capacitor
robmeyer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robmeyer Quote  Post ReplyReply Direct Link To This Post Topic: Naming Convention On The Molded Capacitor
    Posted: 25 Feb 2015 at 4:28am
When I build a Polarized Molded Capacitor the naming of the Footprint is wrong. In 2015.08 it is CAPPM.
From the naming convention it should be CAPMP.
Robert
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2015 at 6:59am
In the Molded Body calculator the auto-generated names are:
  • The Polarized Diode is DIOM
  • The Non-polarized Diode is DIONM
  • The Polarized Capacitor is CAPPM
  • The Non-polarized Capacitor is CAPM
Note that the prefix always ends in M for molded body.
Here is the link to download the standard (which had a typo) - http://www.pcblibraries.com/forum/ipc7351-sm-footprint-naming-convention_topic479.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote robmeyer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2015 at 7:11am
Some days before it was the other typo (CAPMP). Also in your pdf. In the downloadable fpx file the CAPMP is also used. And the POD also have this CAPMP naming.
So is the question why changing a naming convention that works for years?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2015 at 7:31am
Because the "M" (for the package type Molded Body) really should be at the end of the Footprint Name Prefix.
Our goal is to correct flaws to improve the standard for the future.
Ian S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian S Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2015 at 8:49am
In which case, you may wish to correct the remaining typo in the Naming Convention PDF:
CAPPC instead of CAPCP
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2015 at 1:31pm
The Library Expert already produces a CAPPC footprint name.
The Footprint Naming Convention document was updated - Footprint_Naming_Convention_-_Surface_Mount.zip
