  New Posts New Posts RSS Feed - 3D Steps
3D Steps
RogerG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RogerG Quote  Post ReplyReply Direct Link To This Post Topic: 3D Steps
    Posted: 16 Feb 2015 at 6:45am
I have made a new leaded header in the FP Designer but I only get a solid block in the 3D Step.
I made an SSOP which came out with all the pins OK.
Am I missing something out ?
This part was made as user defined package.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2015 at 8:19am
FP Designer only produces a block with radius corners with no terminal leads because 3D models are created with multiple physical component dimensions and FP Designer is a mfr. recommended footprint builder. You get those 3D STEP models from the component manufacturer.
If you created a standard Header, why didn't you use the Through-hole Header Calculator?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2015 at 8:53am
You can also request a high quality 3D model via www.pcblibraries.com/POD and search for the mfr. and part number and the website will transition you to "Request a Part" and request a 3D STEP model for that component package.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RogerG Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2015 at 9:08am
Tom
The reason for using the FP Designer was that there are addition fixing pins, which the through hole calculator does not cope with. If you could edit them after the basis have been done that would be good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2015 at 10:28am
Can you post a link to the mfr. datasheet? I need to see what connector (header) you are building.
