  New Posts New Posts RSS Feed - 3D STEP Model Resolution
omar mahmoud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omar mahmoud Quote  Post ReplyReply Direct Link To This Post Topic: 3D STEP Model Resolution
    Posted: 08 Jan 2015 at 3:15am
We would like to know the resolution of 3D STEP Model of PCB Library Expert software?
For example the default molding resolution would be as 10E-6 mm and how we can calculate it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2015 at 8:48am
You need to get a Free Trial License and test it out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2015 at 9:00am
Please see the "Samples" link at the top of this page:
http://www.pcblibraries.com/Products/FPX/3D-STEP.asp
...or look for the yellow "SEE SAMPLE FILES" link at the link above. Both will get you the same sample file with actual 3D STEP output from the Library Expert. The samples cover a variety of different component families.
nabihm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nabihm Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2015 at 2:32am
We have already PCB Library Expert licence and we used it to generate the footprint and mCAD but we can't detect the resolution of mCAD.
Could you please help us to know the resolution of mCAD?
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2015 at 9:49am
I'm not sure what you mean by mCAD? Is this a specific tool or are you referring to, or a mechanical tool in general? If its the latter, which specific CAD tool are you using? Which translator did you buy a FPX license for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote nabihm Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2015 at 6:07am
mCAD is the 3D Model which we are generating using PCB Libraries Liecence in STEP. We would like to know the resolution of generated 3D Model by PCB libraries.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2015 at 10:02am
There are several User Definable Resolutions -
  1. High Quality
  2. Low Quality
  3. AP214
  4. AP203
