  New Posts New Posts RSS Feed - IPC-7351 Versions
IPC-7351 Versions
edwardgjohns3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote edwardgjohns3 Quote  Post ReplyReply Direct Link To This Post Topic: IPC-7351 Versions
    Posted: 07 Jan 2015 at 6:46am
It seems that PCB Library Expert is using a hybrid of IPC-7351B and the unpublished IPC-7351C.  Which version of the software uses version B exclusively?  Is that software version still available?
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2015 at 8:02am
The Library Expert comes with the default settings to IPC-7351C. However, if you load the IPC-7351B_DefaultPreferences.dat file, you only get the "B" settings.
