3D STEP Model TO-220AB |
omar mahmoud
Topic: 3D STEP Model TO-220ABPosted: 01 Jan 2015 at 6:50am |
How can I build 3D STEP model for TO-220AB? I did not find a Package that fits. Datasheet is - http://www.ti.com/lit/ds/symlink/csd19501kcs.pdfThanks, Omar |
Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 6064 |
Posted: 01 Jan 2015 at 9:32am |
Use the Through-hole > Flange Mount (TO-220) > Horizontal or Vertical.
There is one in the TH FPX file called - TO254P1590X1040X460-3 You can download the SM, TH and BGA FPX files that have over 5,000 Case Codes here - http://www.pcblibraries.com/account/user/memberdownloads.asp You can also download the V2015.06 pre-release with the new 2015 Contour Courtyards for every component family.
omar mahmoud
Thanks(1)
Posted: 05 Jan 2015 at 1:20am |
Thanks for your reply.
I use TH FPX library
but, there are difference between 3d-Model for "TO254P1590X1040X460-3"
and TO-220AB Insulated Package "http://www.st.com/st-web-ui/static/active/en/resource/technical/document/datasheet/CD00002264.pdf". by
the way Mostly TO-220 is Straight package. Rarely it's Horizontal
or zigzag(Vertical) check this document
"http://focus.ti.com/en/download/qlty/MS101206-MISC.pdf"so, i suggest
adding TO-220 Straight package in Library Expert Pro 2015.06. |
Posted: 05 Jan 2015 at 1:19pm |
The TO-220 Straight is already in the program called - Flange Mount (TO-220) Vertical |
