  New Posts New Posts RSS Feed - Hide AND Remove pin in same footprint
Luke View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Luke Quote  Post ReplyReply Direct Link To This Post Topic: Hide AND Remove pin in same footprint
    Posted: 12 Dec 2014 at 2:18am
It does not seem to be possible to both hide and remove pins in the same footprint.  If this is correct I would further guess that this limitation is because of the naming scheme.  It would be great to have this possibility in some cases.
One example are the G6B series relays from OMRON. http://www.omron.com/ecb/products/pdf/en-g6b.pdf
Here, pins 2 and 5( or seven 7) are effectively hidden while the rest of the unused pins are removed (not counted).
Is there a reason this flexibility will not be allowed?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2014 at 11:21am
Mixing hidden and missing pins is not allowed.
It has to do with the format of the fpx library file.
This part can be built in the FP Designer tho.
