  New Posts New Posts RSS Feed - Library Expert 2015.04 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2015.04 Released!!
    Posted: 05 Dec 2014 at 5:04pm
Version 2015.04 was just released!!
FIXED / ENHANCED:
  • User Preferences:
    • Changing LGA pad shape did not work correctly
    • Changing QFN D-Shape Lead to Oblong Pad Shape did not work
  • General:
    • Property Dialog Windows now have two keyboard options when changing values
    • Enter = OK
    • ESC = Cancel
    • The feature “Tools > Edit Physical Descriptions List” did not work
    • Copy/Paste into a new FPX the first time works but reopening the FPX file and Copy/Paste did not work
    • Fixed an issue when saving files which have had rows deleted
    • Tab between dimension cells no allows the user to edit value without having to manually remove the original value
    • User defined Thermal Pad Paste Mask checker board was adjusted to not allow paste outside thermal pad perimeter
  • Altium Designer:
    • Exiting Altium after creating a library via script that hasn’t been saved, will now prompt you to save
  • Expedition:
    • Fixed a problem with the preferences not saving properly
  • 3D STEP:
    • Fixed an issue with setting pin 1 as the origin when dealing with Families which have courtyards made out of open polys (primarily Axial)
