  New Posts New Posts RSS Feed - Add a Revision to the .dat Preference Files
lalexman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Topic: Add a Revision to the .dat Preference Files
    Posted: 23 Nov 2014 at 5:22am
I have custom default and user .dat files that I use each time a new version is loaded. It would be helpful to store a revision number in those files so the software can test to make sure those files are the latest before using them.
The recent problem I had with the LGA round/square pads caused an error message was due to the .dat files I was using did not contain values for the new rounded pads.
As a user we need some way to know when the .dat files we are using are outdated and need to be recreated.
This page was generated in 0.485 seconds.
