  New Posts New Posts RSS Feed - Library Expert 2015.02 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2015.02 Released!!
    Posted: 04 Nov 2014 at 2:48pm
Version 2015.02 was just released!!
FIXED / ENHANCED:
  • Calculator:
    • Fixed an issue where the SMD QFN’s had pads on both Top & Bottom layers
  • Altium Scripting:
    • Fixed a problem with creating through-hole footprints
    • All duplicate Footprint Names are handled and removed. Only the first Footprint Name will be generated and duplicate names ignored.
    • Layer assignments are now editable. Please ensure you use valid Altium Layers.
  • 3D STEP Model:
    • The 3D STEP model will now take into account the Pin 1 Zero Component Orientation
    • TO-DPAK – The Model no longer displays the thermal tab pin, should it be fully recessed into the body
