  New Posts New Posts RSS Feed - Library Expert 2014.12 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2014.12 Released!!
    Posted: 20 Oct 2014 at 11:50am
Version 2014.12 was just released!!
FIXED / ENHANCED:
  • Library Expert Lite: Changed the through-hole default value “On” for “Pin-in-Paste” technology to “Off”
    • Slotted pad stacks - the pad was rotating properly, but the hole was not
    • Through-hole pad stack creation defaulted to Pin-in-Paste
    • Changing a Slotted hole to a Round hole threw an Unhandled Exception Error
    • After inserting a part into a FPX file changing the Component Height was not updating the FPX file in “Update Row”
    • Issue that was causing Columns to be added improperly
    • Added SM, BGA and TH FPX files back into the installation (over 5,000 mfr. case codes)
  • Allegro/OrCAD PCB:
    • When a top pad is circular, and another pad is not but contains the rotation; the rotation will now translate properly to Allegro/OrCAD PCB
    • Free floating areas of copper are now translated properly to the ETCH/TOP layer
  • CADSTAR: Issue that was causing multiple pads on the same layer with certain through-hole parts
  • Ultiboard (Multisim): XML pads stack issue
  • Calculator – Mounting Holes: Changed the GUI text “Supported” to “Plated”
  • 3D STEP: Default Through-hole lead extension value was changed from 0 (zero) to 2 mm in the CAD output menu
  • Default Preferences: When the user creates a personal Default Preference Dat file, the SM Grid Array terminal data changes were not being saved
