  New Posts New Posts RSS Feed - Dual Flat No-Lead (DFN) -- Rounded Rectangle
mike_aes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike_aes Quote  Post ReplyReply Direct Link To This Post Topic: Dual Flat No-Lead (DFN) -- Rounded Rectangle
    Posted: 17 Oct 2014 at 8:30am
Not sure if this is really a bug or not.
In User Setup Preferences under "Dual Flat No-Lead (DFN)" for the "Default Pad Shape" only Rectangle is available.
There is no Rounded Rectangle option.
Not sure if this is due to IPC specs or if this is a slight bug?
Thanks, Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2014 at 10:26am
The DFN and LGA are "Bottom Only" terminals.
The solder joint goal for DFN's is 0 (zero) and the only pad periphery is the lead and manufacturing tolerances. It's a very small periphery (annular) solder joint and rounded corners do not work well.
The solder joint goal for micro-miniature DFN pad size is equal to the lead size and subtracts -0.04 mm to compensate for the lead and manufacturing tolerances. We can't have exposed component leads without a pad under them.
However, the QFN (where the lead goes all the way to the component body edge and up the side 0.20 mm) should have a Rounded Rectangle pad shape. So we're adding that option in V2015.01 as a new feature.
This page was generated in 0.242 seconds.
