  New Posts New Posts RSS Feed - Library Expert 2014.11 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2014.11 Released!!
    Posted: 21 Sep 2014 at 9:25pm
Version 2014.11 was just released!!
FIXED / ENHANCED:
  • Expedition - an issue in the CAD tool export generator that crashed the program
  • PADS - a problem when changing the decal name to a custom name in single part mode
    • An issue in dealing with pins on the bottom layer
    • Pad Stack Manager
      • Ability to reassign pin numbers to pad stacks
      • Custom through-hole pad stack creation
      • Thermal Pad Paste Mask (ability to define the checker board size and gap)
  • Calculator:
    • SOT Component Family – resolved Gang Mask issue related to hidden/missing pins
    • Fixed regression issue with Tools > Regenerate > Name & Description
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2014 at 11:14am
Also updated:
  • Calculator: Design units to mils and set the Silkscreen Pin 1 Dot size to zero
  • FP Designer: Rotate footprint and update FPX Library row was not saving the rotation body dimensions
This page was generated in 0.236 seconds.
