  New Posts New Posts RSS Feed - Eagle - Build Part - Library Description
Evenkeel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Evenkeel Quote  Post ReplyReply Direct Link To This Post Topic: Eagle - Build Part - Library Description
    Posted: 11 Sep 2014 at 5:57am
It would be handy to have the Eagle description text to include a link to the datasheet information from the library when the part was built.  I would put something similar to the following right prior to the <i>PCB Libraries Packages</i> string:
<a href=http://www3.panasonic.biz/ac/e_download/control/connector/base-fpc/catalog/con_eng_p5kf.pdf?f_cd=200062>AXK6F00347Y Datasheet</a><p>
Pulling the info from the Part Number column and prepending it to the string "Datasheet" in the above URL.
Then the Eagle library part has a link directly to the datasheet as defined in the FPX file.
This page was generated in 0.781 seconds.
