  New Posts New Posts RSS Feed - Modify FP Designer Footprint Pin Names
Evenkeel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Evenkeel Quote  Post ReplyReply Direct Link To This Post Topic: Modify FP Designer Footprint Pin Names
    Posted: 11 Sep 2014 at 5:40am
I created a 100 pin connector footprint using the FP Designer (2014.09) and now I want to go back and redefine the pin numbering scheme.  How do I do that most easily (other than recreating the part)?
Billy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2014 at 7:20am
You can double click on any pin and can it's name/number.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Evenkeel Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2014 at 7:50am
Thanks.  I did that for all 50 pins in a row (what a pain!) and then lost the changes because I forgot to press the ADD COMP icon Cry
So, I then just grouped and deleted the entire row of pins and then re-ran the PINS tab to redo them in the proper order.  Much better that way!
Thanks for the reply,
Billy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2014 at 8:08am
That makes sense because you can always double click the first pad a get the coordinates and then delete the row, select the correct pad stack to insert, enter the starting dimension and pitch and number of pins and the new pin number scheme and bam!
