  New Posts New Posts RSS Feed - Drawing a SOT-89 Package
Nico_DD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nico_DD Quote  Post ReplyReply Direct Link To This Post Topic: Drawing a SOT-89 Package
    Posted: 30 Jun 2014 at 6:22am
I can't find the right category under Surface Mount device to draw a SOT-89 package.
There are the SOT23 category or the similar SOT223 category, but is't the same.
Someone have ideas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2014 at 6:51am
There is no Calculator for the SOT-89 due to the various shapes of Pin 2.
You can download specific mfr. SOT-89 packages from Parts on Demand (POD).
There aren't very many of these component packages, so we build all SOT-89 footprints in PADS Layout per the mfr. recommended Land Pattern and put the PADS p/d files on POD for customers to download.
Example: search for DIODES INC. + P/N: ZXTR2005Z-13 and you will find a SOT-89 from that mfr.
I also attached a generic SOT-89 in PADS p/d format. You can use the PADS to CAD translator to convert it to your CAD tool. But there is a disclaimer that most mfr. make their SOT-89 slightly different.
uploads/3/SOT-89.zip
