TO (DPAK) Thermal Tab Under Component Body |
caclark
Joined: 24 Oct 2012 Location: Cincinnati, OH Status: Offline Points: 183 |
Topic: TO (DPAK) Thermal Tab Under Component BodyPosted: 15 May 2014 at 7:46am |
In the last year or so I have seen a resurgence in TO, & DPAK devices that do not have a tab (dim "L1") that protrudes beyond the body. But in the calculator you do not allow "L1" to be a negative number. So I am forced to use FP Designer for this variation on TO & DPAK's.
So what should take me only a few minutes to calculate takes me more than 30. And even at that I am required to have supporting documentation for all parts I create, and the FP Designer output print is no where near acceptable, so I then have to spend another 30 minutes creating documentation. Ref device: Manuf:TI PN: LMZ14201HTZ |
chrisa_pcb
Joined: 29 Jul 2012 Location: San Diego Status: Offline Points: 772 |
Posted: 15 May 2014 at 10:22am |
We'll look at getting this into V2014.03, it should be an easy fix. That's scheduled for release in ~2 weeks.
Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 6069 |
Posted: 26 Jun 2014 at 8:20am |
We updated the TO (DPAK) in V2014.05 to allow the user to enter a negative value for the tab "L1" dimension. This allows Library Expert users to create DPAK's with Thermal Tabs under the component body. http://www.ti.com/lit/ds/symlink/lmz14201h.pdf
