  New Posts New Posts RSS Feed - Library Expert 2014.02 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2014.02 Released!!
    Posted: 11 May 2014 at 5:33am
Version 2014.02 was just released!!
NEW:
  • Librarian Feature:
    • Automatically load the user default FPX library defined in User Preferences (this is in addition to the command line library load and open)
  • Email Notifications of new version releases (not via this forum) begin with 2014.03. If you have not subscribed to these upon registration, or if you registered before this option was available, subscribe to release alerts here. Please be sure to confirm your opt-in via the email you will receive!
FIXED / ENHANCED:
  • PADS Layout:
    • .d ASCII files will now properly use degrees, rather than tenths of a degree, when outputting to a format older than V9.0
  • CADInt:
    • Units issue that was preventing parts with copper finger shapes from importing properly
  • Altium:
    • Issue that was preventing the Polarity dot from being converted from a label to a shape
  • 3D STEP:
    • SODFL – Lead generation and placement, and cleaned up the 3D model body
  • General:
    • 3D part of the Translator Window to be visible (although not active), if you didn’t have a 3D License
This page was generated in 0.548 seconds.
