  New Posts New Posts RSS Feed - explain the bottom section 3d TH
mytime View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mytime Quote  Post ReplyReply Direct Link To This Post Topic: explain the bottom section 3d TH
    Posted: 09 May 2014 at 2:20pm
TH Lead   What is that? the length of the lead
Post Options Post Options   Thanks (1) Thanks(1)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2014 at 2:56pm
TH Lead Length is the length that a through hole lead extends beneath the origin, with a minimum of .1mm so that the model maintains its structure. So if you select 1mm, the leads will extend to -1mm in the vertical axis. Its done this way so that you can specify a board width(which might change), and be able to see the pins of the part poke out the opposite side.
This page was generated in 0.390 seconds.
