  New Posts New Posts RSS Feed - BGA After Import Loses Apha Part of Pin Numbers
davefuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davefuller Quote  Post ReplyReply Direct Link To This Post Topic: BGA After Import Loses Apha Part of Pin Numbers
    Posted: 15 Apr 2014 at 5:12pm
After making a BGA build and export into PADS ver 9.4,  I noticed that my Alpha part of the pin numbers got converted to all numbers.   Is there a way to avoid having to edit those in PADS one by one?   Am I missing a step?    The Alpha labels were there when I did the build?
Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2014 at 5:23pm
The Alpha-numeric pins are in the "Part-Type".
Unselect the "Map Alphanumeric Pins" in the Translator Dialog if you want them to be in the "Decal".
