Printing: More Output Possibilities |
Post Reply |
Author | |
FranzR.
Active User Joined: 13 Mar 2014 Location: Germany Status: Offline Points: 35 |
Posted: 19 Mar 2014 at 8:02am |
is it possible, to get settable printing options for output a detailed documentation of the current displayed part and options? for e.g.: - Settings - Terminal --> Settings, Environment, ... - Rules - Drafting - Assembly, Courtyard, .. ... - Program Version, Warnings - Current name of configuration So it can completely reproduced (*.pdf) with which configuration the part was built, or if the current settings are changed before build. Because i have seen, that if the component settings were changed an the part was saved in the library, than the changed settings are not included in the library and the builded part was not repeatable. Here was an example made with LP Wizard: |
FranzR.
Post Reply | |
Tweet |
Forum Jump | Forum Permissions You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
