  New Posts New Posts RSS Feed - Import of LP-Wizard Library plb09
FranzR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FranzR. Quote  Post ReplyReply Direct Link To This Post Topic: Import of LP-Wizard Library plb09
    Posted: 13 Mar 2014 at 1:44am
I have seen, that bevore the integration to Mentor Graphics, the LP Wizard was on your history...
6th          LP Calculator & LP Wizard with new .plb09 file format for library + new GUI V2009 (added different units for mils, inch, millimeters and micrometers and through-hole component families)(added Eagle & McCAD)
7th          PCB Footprint Expert with new .fpx file format for component dimension library V2012 (with support for all major CAD tools!)
So i think you know this old Format.
Is it possible to import the .plb09 files of an own library into PCB-Library Expert? Or is there a File-Converter?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2014 at 4:20am
We started to put together a converter, but it doesn't work perfect. If you're interested, let's discuss offline.
This page was generated in 0.439 seconds.
