  New Posts New Posts RSS Feed - Part attributes going to target library
SteveD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveD Quote  Post ReplyReply Direct Link To This Post Topic: Part attributes going to target library
    Posted: 01 Mar 2014 at 6:34pm
When we 'export' our library from the Expert to a PADs library, we want all the part attributes to go with it.  But it looks like until you can also export a schematic symbol to attach those attributes to, there is nothing to hang them on.
Is that correct?  If incorrect, how can we get the attributes to accompany or otherwise attach them so they show up in a BOM?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2014 at 8:03pm
PADS Layout attributes default to the "Part Type". This includes Pin Rename and Alphanumeric Pins.
If you want Alphanumeric Pins to always be in the "Part Decal" then unselect the "Map Alphanumeric Pins" option in the CAD Tool Export menu and select "Save Entries as Preferences" so that it is always unselected.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2014 at 4:40pm
Currently we don't support custom attributes. The only two that are currently generated are Description and Geometry.Height.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveD Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2014 at 9:37pm
I am seeing also a case code, manufacturer, and a data sheet.  Then there is whatever we may add when we create the library.
Is there no way to carry that information over to PADs so that it ends up available in that library (so that we do not have to reenter it).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2014 at 7:37am
We are going to be running New Feature Poll questions when "Parts on Demand" (POD) is released.
We get most of our poll questions from this forum - Product Suggestions
http://www.pcblibraries.com/forum/product-suggestions_forum33.html
10,000 PCB designers will be invited to take the 1st poll to determine which new features they want the most and that is where the software programmers will get there workload for 2014.
We'll be sending out our first Newsletter inviting our customers to vote this month.
